Viewsonic tv problems
Last response: in Home Theatre
July 14, 2011 2:56:13 AM
My Viewsonic TV model N3250w. Problem to turn on have to press swich 50 times befor TV will start,what can be done about it ? Guenther Szymanski
More about : viewsonic problems
a b x TV
July 15, 2011 5:08:11 PM
Power supply bad, take to repair shop.
m
l
July 22, 2011 8:37:58 PM
After $ 260 it is working again, wonder for how long. TV's used to work for 20 Years,
not anymore, 5 years maximum and the sucker is kaputt.
m
l
August 1, 2011 2:52:21 AM
Will I ever buy a Viwsat TV a gain? I do not think so,unless you refund the repair money, it was only $260.00
m
l
September 16, 2011 2:54:38 AM
I'm having the same exact trouble. What did you have done to fix the problem? Who did you call?
m
l
November 14, 2011 4:14:05 PM
6 bulged capacitors replaced on the power supply solved my problem same as this one.
3,50$ total parts + ride to electronics shop.
You can order the whole power supply online...search for N3250w powersupply on google, you'll find.
about 45$ USD...
Good luck
m
l
