Volume Control
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.general (More info?)
I'm using an IBM Thinkpad laptop with WinXP SP2. I have the volume control
levers all slid up to the highest level, and it was working fine until
yesterday when the IT people at work set up a docking station for me. Since
I've been home (no docking station), the volume is really low. I've checked
volume control and the settings haven't changed. IT says they didn't do
anything to the volume. Any ideas?
More about : volume control
Hi,
Laptops often have a volume control that uses the function (Fn) key and some
other key on the board. It may have been turned down inadvertantly, check
the user manual or help files for the proper key combination to turn the
volume up or down.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Andrea" <andreawknospam@nospamcox.net> wrote in message
news:RnaLe.337$Ji.280@lakeread02...
> Since I've been home (no docking station), the volume is really low. I've
> checked volume control and the settings haven't changed. IT says they
> didn't do anything to the volume. Any ideas?
Actually this computer has volume buttons on the keyboard, but I'd forgotten
about them. That solved the problem. Thanks so much.
Andrea
"Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
news:o Skorg5nFHA.3288@TK2MSFTNGP09.phx.gbl...
> Hi,
> some other key on the board. It may have been turned down inadvertantly,
> check the user manual or help files for the proper key combination to turn
> the volume up or down.
> Best of Luck,
>> control levers all slid up to the highest level, and it was working fine
>> until yesterday when the IT people at work set up a docking station for
>> me. Since I've been home (no docking station), the volume is really low.
>> I've checked volume control and the settings haven't changed. IT says
>> they didn't do anything to the volume. Any ideas?
You're most welcome Andrea.
Best of Luck,
news:bOaLe.339$Ji.185@lakeread02...
> forgotten about them. That solved the problem. Thanks so much.
> Andrea
>> Hi,
>> turn the volume up or down.
>> Best of Luck,
Ask the community
