Jezzy
Hello,
My husband has been busy moving my beloved Technics turntable around (different shelves, floor, disconnecting cables, etc.) and now, the speed is so whacky, I can't use it or figure out how to fix it. Next, there is a humming problem when I lift the arm. Any help or suggestions are appreciated.
Thanks!
G
Guest
Guest
This topic has been moved from the section Forum Feedback to section Home Audio by Grumpy9117
G
Guest
Guest
Which model Technics ? Is the speed simply wrong or is it wavering ?
The humming is probably because you have not reconnected the earth wire between the turntable and the amplifier's earthing post.
