Receiver with audio delay feature ?
Last response: in Home Theatre
Yeah, if I understand you correctly, many receivers have a feature for audio delay to compensate for varying acoustics and distances, often time they are automatically set up during Auto-Setup made by a special microphone. $2000 is a good budget, are there any specific requirements you have for it?...such as weight, brand, features?
Related ressources
well my concern is good quility and nice brand . i want to add it up with yamaha rxa 3000 r maybe with out rxa 3000 dirctly . hope u find some thing for me. do u thing i should just add some good brand pre set effect machine r what ever u call it to get digital effect like hall eco stadium room and much much more like these effect ? thanks
I think a good receiver will do everything you need really. Brands I recommend looking into are:
-Marantz
-Denon
-Pioneer
-Harmon Kardon
-Yamaha
^Those are just some of the many good brands out there. If I had a 2000 budget, I would look into these receivers:
http://us.marantz.com/us/Products/Pages/ProductDetails....
http://www.pioneerelectronics.com/PUSA/Home/AV-Receiver...
http://usa.yamaha.com/products/audio-visual/aventage/rx...
^Those are a few I would look into, look for good deals basically.
-Marantz
-Denon
-Pioneer
-Harmon Kardon
-Yamaha
thanks i will look in to these receivers and will talk latter thanks again
Ask the community
