Hi guys, just a quick one.
Doing a laptop battery test and wanted to know what you would suggest as a quick battery drain. I'm not after anything real-world, just something that will hammer the machine and get the test out of the way pretty promptly and preferably in a way that it doesn't matter what else is installed!
I don't need any sort of a timer or anything as I have 2 systems that will just sit next to each other and duke it out!
These are identical single core Intel systems with Nvidia Quadro NVS 110M GPUs.
Cheers
Cheers
