uninstall problem
  • Control Panel
  • Microsoft
  • Windows XP
Last response: in Windows XP
Anonymous
August 14, 2005 3:11:18 PM
Archived from groups: microsoft.public.windowsxp.general (More info?)
Whenever I try to uninstall a program through its uninstall application Nero
Mix pops up which is totally irrelevant as far as I can tell. Uninstalling
through the control panel is no problem but I'm under the impression that
the best way to uninstall is through the program itself.
thanks
John
More about : uninstall problem
Anonymous
August 14, 2005 4:29:57 PM
John
There should be no difference uninstalling via Add/Remove and
uninstalling via the program's uninstall application as the program
supplies the Add/Remove entry.
What is the Target of the particular uninstall application(s) you are
having the problem with?
(Right-click the uninstall shortcut, select Properties and see what
the exact target is")
....Alan
Alan Edwards, MS MVP W95/98 Systems
http://dts-l.org/index.html
On Sun, 14 Aug 2005 11:11:18 +1000, "John & Chris"
>thanks
>John
Anonymous
August 15, 2005 12:32:00 AM
Thank you Alan
The program is gone so I can't answer your question but I'll save your email
and next time I'll follow your suggestion. In the meantime that's a good
point to know about the Add/Remove facility in the control panel.
thanks again
John
"Alan Edwards" <edwards@southcom.com.au> wrote in message
news:9oatf11p7uglfurgqeuu36agtqjfkq1ais@4ax.com...
> John
> ...Alan
>>Nero
>>Uninstalling
>>thanks
>>John
