Comment on Audio quality of this Cellphone
shubham1401
Hey guys! :hello:
I hope this is the most appropriate section for my query...
I have a Nokia 5230 and I was just going through this review on GSMarena and they did some Audio Quality tests..
There is a "Perfect Audio Quality" section under which there are some readings (Frequency response, Noise level etc etc )
Though I was not able to infer anything from the data so I would like you to help me and tell me how does it compares to other phones given in the table just on the basis of audio quality
Thanx in advance :)
the apple wins
it has flatter freq response,
lower noise lvl (lower the better)
higher dynamic range ( difference between the quietest sound and the loudest, the higher this value, the less 'flat' it sounds)
lower crosstalk, there is less leakage of sound going to opposite channels.
MEgamer
1,424
the apple wins
shubham1401
Thank you very much for your response... :)
BtW where does Nokia 5230 stands as compared to apple and the other ones?
shubham1401
Hehe... No problem.. It is significantly cheaper than other phones in the list (1/5th cost of an Iphone here) and paired with my Sony In-earphones the sound quality is quite satisfying....
I Just wanted a comparison as they said "Perfect Audio Quality" :pt1cable:
