Archived from groups: rec.games.pinball (
More info?)
are the switches functioning correctly? If the ball isn't detected in
the first ball lock it will keep sending the balls there.
Jason Danziger wrote:
> Thats what it does, the ball goes to the lowest wire ramp. It should get
> diverted to the top or middle ramp to the holding area where it is reshot
> out onto the playfield but this does not happen.
> It has nothing to do with the plunger as that is all new along with the
> rubber.
> What can I do to get the top and middle diverters to function again? Could
> it be a resistor or transistor on the CPU board, as I tested them all and
> they are all good.
> Thanks again.
> Jason
> <gixxerdude1000@yahoo.com> wrote in message
> news:1120007304.229971.164320@g44g2000cwa.googlegroups.com...
>>A bad diverter won't make the ball come all the way back down the
>>shooter lane. Only a bad shooter spring or shooter alignment would
>>cause the ball to fail reaching the diverter. Also, opening and
>>closing the pf could have 'shaved' the tip off of the rubber. Does it
>>make a 'clink' sound when you launch the ball?
>>On my F14, the lower diverter had interference with the ramp itself. I
>>placed a beefy washer(1/16" thick) at the post right near the lower
>>diverter (between post and ramp) to create clearance. This worked like
>>a champ. The diverters on F14 are seperate - not like in High Speed
>>where they are linked/timed. It doesn't sound like the problem you're
>>having. A failing diverter would cause the ball to always take the
>>path of the lowest wire ramp.
>>>On my F-14, the ball diverter does not function and the ball comes all
>>>around back to the shooter lane. What part of the CPU board should I
> check
>>>that is linked to the diverter which holds the ball once each ball is
> fired?
>>>Thanks.
>>>Jason
Cliffy - CARGPB2
A passion for pinball!
http://www.passionforpinball.com
