Archived from groups: microsoft.public.windowsxp.general (
More info?)
For now, I would download the latest Defs package directly.
Available here:
http://download.lavasoft.de.edgesuite.net/public/defs.zip
Just unzip the module to obtain the .Ref file and copy and paste
it into the AdAware folder in Program Files.
If I read your response correctly - you're using NIS ? have
checked that your Live Update is the latest version. Many
times Live Update won't update Live Update. The latest version
of it is available at: (2.7.34)
http://www.symantec.com/techsupp/files/lu/lu.html
After updating Live Update (if necessary) you'll need to run
LU repetitively until all updates are applied.
"Rune L Meyer" <runelisethmeyer@hotmail.com> wrote in message
news:01309C87-BB02-4D12-8D49-3C9680E1BD14@microsoft.com...
> Hi,
> Yes, I've done ALL updates, re-set computer each new installation. Updated
> Symantec, Virus & Internet.
> Tested the system with chkdsk = NOT DIRTY.
> Still, it doesn't log onto internett, when looking for updated def files
> for
> AD-WARE SE f.ex
> Is there any tool, I can run from win?
> Thanks!
> Best regards
> RLM
> "R. McCarty" wrote:
>> Regclean after a re-install ? That's not an appropriate troubleshooting
>> tool.
>> If the computer "Hangs" then something is not configured properly or
>> you've
>> got system level issues (Drivers). Abrupt power offs (Not a Reset) can &
>> will cause XP to not flush data to the drive. This will likely cause the
>> drive
>> to be marked "Dirty" and need a Chkdsk to restore integrity.
>> If this was a "Fresh" install - did you update your Motherboard Chipset
>> drivers ? & have you installed all the Critical Windows Updates to the PC
>> I don't think your system requires "Cleaning", but proper configuration &
>> updating should resolve the problems.
>> "Rune L Meyer" <RuneLMeyer@discussions.microsoft.com> wrote in message
>> news:33DC5F6B-6FF3-4189-B53C-07C7E5732BDA@microsoft.com...
>> > Hi,
>> > After re-installing MS XP Proff, and all MS Updates, I'm having trouble
>> > when
>> > installing other programs, who like to update through internet.
>> > Expl: Lavasoft AD-AWARE needs to get connection to internet for updated
>> > def
>> > file. System the hang, does not respond to anything. Must reset PC,
>> > ON/OFF.
>> > Tried Regclean, this has sorted out some problems, but I think I need
>> > deeper
>> > cleaning.
>> > I need ASAP answers, since I'm running business.
>> > Any good tools, to get problems fixed/analysed?
>> > Thanks!
>> > Best regards
>> > RLM
