Turn Off Laptop LCD
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Is there a way to turn off the LCD while leaving the laptop
(particularly the D610) running (and not connected to a second monitor)?
I mainly want to do this for when I'm compiling on battery and don't
need to see the output; on my previous laptop I simply pressed the
button which switched it to vga out (it had 3 modes: laptop only, vga
out only, both).
G
Guest
Guest
you can just set your power management settings to turn off monitor after x
amount of minutes of no use
"Nicholas Andrade" <sdnick484@nospam.yahoo.com> wrote in message
news:tjl3e.11426$zl.10138@newssvr13.news.prodigy.com...
> Is there a way to turn off the LCD while leaving the laptop (particularly
> the D610) running (and not connected to a second monitor)? I mainly want
> to do this for when I'm compiling on battery and don't need to see the
> output; on my previous laptop I simply pressed the button which switched
> it to vga out (it had 3 modes: laptop only, vga out only, both).
G
Guest
Guest
Thanks for the suggestion; that's good for when I'm running Windows,
unfortunately that doesn't help me in Gentoo Linux (where I do most of
my compiling).
