Pc doesn't detect sound card
zahak
Hi
I don't know where to put this thread but i can't seem to find a way to put my sound card working.
It's a creative sound blaster live! (model SB0060). I tried (and found) the drivers for this card, but everytime i try to install the drivers,
it says there isn't any sound blaster card in the computer.
Im using windows xp 64 bit and the drivers i got are for this operating system.
In the "sounds and audio devices" i get "no audio device", and there is no exclamation markers on "device manager".
I've also disabled on-board audio card in BIOS.
Tried to put sound card in different PCI slots but doesn't make a difference.
Need help! Thanks. (if more info is needed, ask)
answer
Last reply
More about doesn detect sound card
Is it the right driver for that model and Windows version -- 64 bit drivers can be a little hard to find.
Moving PCI slot is a good idea. Also try freeing up resources -- look at BIOS screens and see if you can disable COM ports, Parallel Printer port (if using USB printer).
Restart Windows a couple of times to reassign resources.
Drivers
Sound Blaster
Sound Cards
Audio
Related Resources
- Sound Blaster X-Fi Titanium Fatal1ty Pro Series Troubles
- Sound Blaster Live! 5.1 Driver Help
- Will this old Card improve my sound quality
- The best gaming sound card
- Sound Card - Want to input both DVD & CD-ROM - How ?
- Sound Card vs. Onboard Sound
- Non-Creative Sound Card
- Creative SB0090 Sound Blaster Audigy SB1394 Pci sound card driver help
- Help me decide sound card for Klipsch Pro Media 2.1
- Getting a old sound card, will it be better than my on-board?
- Will sound blaster 5 1 Live work with Windows7?
- Sound device & sound card
- Using Creative Sound Blaster Live! with Windows 7
- Recommend a Sound Card
- Sound blaster audigy se driver issue
- Can't find working driver for Creative Sound Blaster Live! (CT4830) (running windows 8)
- Onboard audio v. Creative Sound Blaster Audigy SE 7.1
- Sound blaster recon 3d or sound blaster Z
- Sound Blaster Live 5.1 AND 24-Bit won’t be detected
- Creative 5 1 driver with wave studio
