TEAC 3340S technical help
My Teac 3340S records only on channel 2
All four channels and VU meters working when mikes plugged in and selectors set to "source"; red record lamps light up on channels 2, 3 and 4. (I have not tried changing the bulb yet)
Only channel 2 gives an output when selectors set to "tape"
Also, "pause " button puts deck into rewind mode not pause!
1 answer Last reply
More about teac 3340s technical help
  1. a lot of times the transistors go bad in teac decks. A good audio shop can fix it up, the transistors can be replaced with off the shelf types, and it will work quite well again.
    Also, replace the belts.
TEAC Light Audio
