Tom's Hardware > Forum > CPU & Components > CPUs > any helpful adbvice with a start up problem
Forum CPU & Components : CPUs - any helpful adbvice with a start up problem
I just finished hooking up the last IDE cables and power cords, and all i get is the a quick spin from the fans and then nothing. If I push the power button again, the fans will not even spin again. The only way they will spin is if I unplug the power cord form the back of the machine and then hit the power button. Then again, the fans only spin for a split second and then NOTHING! Is this a problem with the CPU?
Sponsored Links
Is the HSF mounted correctly? Sounds like it's shutting down before it fries itself.
Or reset the CMOS it could be that as well.
With so little info on your system those are the only guesses I can give at this point.
If it ain't broke, take it apart & see why not!
Reply to RCPilot
Most likely is your mobo shorts to ground. Try to boot it outside the case.
:smile: Good or Bad have no meaning at all, depends on what your point of view is.
Reply to khha4113
Usually when I've seen this the AGP card is sitting 2-3mm high in the slot. Reseat all your cards (AGP & PCI), and maybe your RAM. If that doesn't do it, you'll have to start removing/swapping parts until you figure out what's causing your problem.
<font color=blue>Learn from the mistakes of others. You won't live long enough to make them all yourself.</font color=blue><font color=green>
<i>Canadian Flight Safety periodical, ~1987</i></font color=green>
Reply to Traqr
Plugging in a computer usually makes the fans spin for a moment. Your description doesn't even allow us to know if the power switch on the front pannel is connected to the right pins. Please read the first post in the Motherboard's forum for usefull tips.
<font color=blue>Watts mean squat if you don't have quality!</font color=blue>
Reply to Crashman
I have actually had this problem before. In my case what it turned out to be was that the cord from my monitor pulled tight when I was moving it and managed to shift my gforce so that it wasn't in the AGP quite right anymore. I pushed the card back in all the way and everything started up fine. This happened a second time and I overcame my inherent lazyness and slid my case over a few inches.
Reply to bandikoot
AGP cards are <i>notorious</i> for bad connections. You wouldn't believe how many system failures I've fixed simply by removing and reinserting the video card.
---><font color=green>It ain't better if it don't work</font color=green><---
Reply to Teq
There are 1175 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
