What is the BEST color temp setting for a PC Monitor (LCD).
Last response: in Computer Peripherals
March 5, 2010 2:41:01 AM
I have a Viewsonic vx2433wm and i was wondering what the BEST Color temp setting is:
sRBG
9300K
7500K
6500K
5000K
Just curious because i had it set to 9300K because i liked the blue tint, but what is the most accurate? All the others look WRONG, prolly because im used to the 9300K... I want my pictures to look as acurate as possible, but i cant see the difference because im swayed by the fact that I like the 9300K because im used to it. :pt1cable:
THANKS! :lol:
a c 195 C Monitor
March 5, 2010 5:42:22 AM
Generally speaking sRGB will give you the most accurate colors, however, you still need to calibrate your monitor to get the most accurate colors possible. Purchasing a colorimeter would be a good idea if you really want accurate colors. Generally speaking, the more expensive the colorimeter, the more likely your monitor will be optimized.
The "poor man's" way to calibrate your monitor is to go to the following site:
http://www.lagom.nl/lcd-test/
m
l
March 5, 2010 10:27:33 AM
if you use windows 7, it comes with a color caliberation program. i dunno how accurant it is but when i used it, it seemed to improve my colors. before i used it i had a slight red tint i didnt notice till i used the caliberation program.
m
l
a b C Monitor
March 8, 2010 11:49:23 PM
6500K is the standard for new monitors.
m
l
a c 195 C Monitor
March 9, 2010 10:08:58 PM
6500K has been the standard for all monitors.
m
l
