The kind of file system didn't have anything to do with your particular error. Formatting and reinstalling the operating system is what corrected the problem.
It didn't matter what file system you choose for the partitions, or whether you created one or more. Many people are running WinXP with either of the file systems, and with no errors.
I think having two partitions per hard drive is a good idea, but that didn't have anything to do with the error, either.
The technician you talked to <i>accidentally</i> got it right. Partially, anyway. But you could have simply repaired the Master Boot Record or the Boot.ini file and done the same thing ... or as you did ... wipe the system partition clean and reinstall the operating system.
The fact is, many technicians recommend the exact reverse of what you were told ... to install the OS into an NTFS partition, and that the other partitions should be formatted as FAT32.
It's my personal opinion that mixing and matching file systems on the same hard drive is not always a good idea. I've seen some instability issues occur as a result of this.
You should be aware that most so-called technicians are not the most caring, or the best educated people. And half the time, you aren't actually talking to a tech ... you are talking to a customer service rep, pretending to be a tech, who would probably need help to recognize a floppy drive. (You might think I'm exaggerating ... but I met such a person.) These days, it's like flipping a coin when you look through the Yellow Pages to find a family doctor. Somewhere out there is the worst doctor. He may be just barely qualified to practice medicine, but he's treating someone ... right now!
Finding a well-trained technician with good troubleshooting skills can be even harder ... IMHO, a truly exasperating experience.
Toejam31
<font color=red>First Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=17935" target="_new"><font color=green>Toejam31's Devastating Dalek Destroyer</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
__________________________________________________________
<font color=purple>"Some push the envelope. Some just lick it. And some can't find the flap."</font color=purple>
