Im currently running a xp1800. The default speed for these is somewhere around 1.53 ghz. When the computer boots up now, instead of that it says running @ 1143. BeZ is mad
There will be either jumpers to be set or a BIOS setting you have to change. It's a little different on each motherboard, so check your motherboard's manual...
---><font color=green>It ain't better if it don't work</font color=green><---
