Sign-in / Sign-up
Coaxial audio output
  • DVD Players
  • Cable
  • Audio
  • Home Theatre
Last response: in Home Theatre
September 20, 2011 3:39:37 PM
Hello,
i have n older rotel pre amp with a db25 surrond sound input can i get an adapter / cable to go from the RCA coaxial audio output on dvd player to the DB25 input thanks
More about : coaxial audio output
September 30, 2011 5:52:47 PM
I am not sure but I think the DB25 connection was an output to go to a multichannel power amp and avoid having to use multiple audio cables. Check your owners manual. If your Rotel does not have a digital input then use the L/R RCA audio output into the Rotel. If you have run out of inputs then you need to add a switch box to do that.
m
l
October 13, 2011 12:15:36 AM
its definatley labeled 5.1 channel input the pre amp has rca jacks that connect to the rotel poser amp for front rear center etc on the surround sound.
m
l
October 13, 2011 5:33:40 PM
Check with Rotel and see if they can supply you with what you need or at least the pin pattern of the DB25 and maybe the connector itself. Then you can have a cable made. Might be cheaper to add a audio switchbox.
m
l
