SONY INTEGRATED STEREO AMPLIFIER MODEL TA-AX311
Is there a replacement for a Sony Integrated Stereo Amplifier model TA-AX311?
2 answers Last reply
More about sony integrated stereo amplifier model ax311
  1. any integrated stereo amp will replace it, usually a matter of cost to find a suitable choice.
    Thanks for your reply soundguruman
    The original amplifier that came with the stereo component system (SEN-311) uses two flat remote control cords for connections to the tuner and tape deck (a single connection for the tuner and a dual connection for the tape deck). The manual calls this a "system control". Standard connections are used for other components (CD player, phono and video).
    I would prefer the replacement amplifier have these same features.
    Are there new amplifiers availabe with these remote control cord connection? The system was purchased in 1992 for $792.
    Thanks, Gene Mc
Sony Audio
