G Guest Guest Jun 10, 2010 #2 I got the same problem the power light dose not come on no matter what. Upvote 0 Downvote
G Guest Guest Jun 10, 2010 #3 It's probably the power supply unit -- often capacitor failure. Good news is that capacitors are cheap and simple to replace if you have basic knowledge of electronics and soldering. If you don't, it should work out as a cheap job by a repair guy. Upvote 0 Downvote
