hiya all,
I have a problem.....
Just recently I got an Athlon XP 1700+ to replace a Duron in an ASUS A7V333 mobo. I have installed AMD cpu in the past with no problems. I used a
Thermaltake Volcano 6CU+ HS/Fan, to test installing it on
the Duron first, and the cpu totally died. It acted like just the Heatsink touching the cpu surface shorted it out or something. The cpu hasn't a mark on it but wont work no more. I am worried that if I do the same, the Athlon XP will do that as well.
This heatsink has a copper base, and I used thermal paste exactly like usual.
So my question is, is this possible? This is the first time I've come across this sort of problem. Is there any steps I can take to ensure this doesn't happen?
I thought about using a shim if its a heatsink related issue, but I hear there are problems with those in themselves. Any help is appreciated.
~Dyl
~Dyl
