G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hi,
Just a couple of things with my HSII I would like a bit of help with.
#1. During play the Kicker sometimes fires for no reason, I thought of a
Phantom Switch could be causing it however it can occur when the ball is
anywhere on the Playfield, its getting a bit annoying because it usually
happens when your going for a Lock Shot and it Kicks and the Up/Down Ramp
lifts thinking a ball has just been launched.
#2. This one is to do with the Supercharger, mine seems to be going way
to fast and at times it can get going that quick that the ball slams into
the Plastic over the Diverter, my Plastic has a crack in it from this
problem and I have ordered a replacement but I don't want to change it yet
because the ball still hits it, so is there any way to slow the Supercharger
down? I was going to try disconnecting either the 2nd or 3rd magnet to see
if this can slow it down, has anyone had this problem?
Thanks for all the help.
Kevin
Hi,
Kevin
