Question about Firefox
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I keep reading about this browser.
I have a Dell Dim. 2400 system with XP Home.
I've been using IE.
Some basic questions:
1) If I go to Firefox, when I d/l it, can I make it my default browser but
keep IE and switch to it if needed??
2) I use OE for mail. Can I use Firefox AND OE??
3) Will pages load much faster with Firefox??
Mel
G
Guest
Guest
In article <1u9Xd.1894$Fn7.1018@fe02.lga>, mel@prodigy.invalid.net
says...
> I've been using IE.
You have my deepest sympathies.
Yes, but I think you may find it hard to go back to IE after you
get acquainted with Firefox.
OE is a horrible virus vector, and bloated beyond belief. The
answer is 'Yes,' but you should take a very hard look at Thunderbird (an
E-mail client from the same folks who gave us Firefox).
It looks like it to me, but load speed is dependent on a whole
slew of factors.
Happy tweaking.
Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute.
(Known to some as Bruce Lane, ARS KC7GR,
kyrrin (a/t) bluefeathertech[d=o=t]calm -- www.bluefeathertech.com
"If Salvador Dali had owned a computer, would it have been equipped
with surreal ports?"
G
Guest
Guest
Answers interleaved with your questions...
>I've been using IE.
Yes. Definitely.
Yes. Firefox does not prevent any other software product from being used.
Not especially. To me, it runs about the same as IE. But popups are blocked in
the default setup, so you could say that popups load so fast that you don't even
see them... Ben Myers
>Mel
Dave
2,727
On Mon, 7 Mar 2005 20:31:12 -0800, Dr. Anton T. Squeegee
>says...
>> I've been using IE.
>slew of factors.
> Happy tweaking.
Firefox may seem faster, but testing shows it's about the same as IE.
But it's security, features, and extensions are great.
http://www.howtocreate.co.uk/browserSpeed.html
Dave
G
Guest
Guest
You can also use a tiny extension program called ieview. A right click of
the mouse invokes IE.
Ma
G
Guest
Guest
"Ma No" <kin@earthkink.ten> wrote in message
news:mYsXd.5169$cN6.4347@newsread1.news.pas.earthlink.net...
>> but keep IE and switch to it if needed??
> Ma
Cool! Have a link handy? If not I can google it.....
Stew
G
Guest
Guest
>> Ma
If you run XP you can use "Set Program Access" defaults to make FF the
default browser and also delete access to IE - and it's build into XP.
Try Control Panel, Add remove programs, select icon on bottom left....
spam999free@rrohio.com
remove 999 in order to email me
G
Guest
Guest
" delete access to IE"? You mean prevent regular use of IE, don't you?
IE still has to remain in the XP program menu to make possible Micro$oft's
automagic software updates... Ben Myers
>>> Ma
G
Guest
Guest
I didn't say delete IE, I said delete access to it - should have said
disable access to it - meaning the user can not launch IE and the IE icon
will not be available.
>>>> Ma
G
Guest
Guest
You guys misunderstand. I was asking Ma No for this link:
https://addons.update.mozilla.org/extensions/moreinfo.php?application=firefox&id=35&vid=1179
Stew
"Leythos" <void@nowhere.lan> wrote in message
news:pan.2005.03.09.03.25.33.182305@nowhere.lan...
>> Micro$oft's
>>>>>> browser
>>>>> of
>>>>> Ma
G
Guest
Guest
Wow. Thanks for the multitude of responses.
I did d/l FIREFOX. I like it so far. It does APPEAR to be MUCH faster than
my IE 6.0 (although one of the responses here seemed to show research that
indicated this wasn't the case).
I am going to keep my IE and its icon. I'll use that for Windows Updates,
etc.
It will be fun to explore FireFox features, whatever they are.
In fact, I'll set up a new thread for that.
Mel
"S.Lewis" <stew1960@cover.bellsouth.net> wrote in message
news:i%tXd.13113$6g7.9698@bignews1.bellsouth.net...
> Stew
>>> Micro$oft's
>>>>>>> browser
>>>>>> click of
>>>>>> Ma
