What is the reason for the install, uninstall and now the attempt at another install ?
If you now want to install this Sony reader hen you'll have to remove all traces of the previous install.
Go to the control panel and add/remove programs and make sure that you have removed all trace of it. Then empty the recycle bin and do a restart and that way it should take all trace of it out and you can try a new install of the device.
