Solved
Picture to HDTV, and sound to Surround sound from laptop. HELP!!
  • HDTV
  • Laptops
  • RCA
  • Cable
  • Home Theatre
Last response: in Home Theatre
October 19, 2011 10:56:54 PM
I am trying to connect my laptop to my Coby HDTV for a great monitor, while at the same time get the 5.1 dolby surround sound from my laptop through my RCA 5.1 surround sound box (not the cable "rca"). I have an optical cable, HDMI cable, and an rca to rca cable. Display to HDTV works but I get no sound from surround. Any thoughts?
More about : picture hdtv sound surround sound laptop
October 19, 2011 11:05:57 PM
I should clarify that I tried to connect the HDMI to the HDTV from laptop. Then tried to connect the optical cable from the HDTV to the optical IN port on my RCA Surround sound and get no sound but only picture.
m
l
a b D Laptop
October 20, 2011 2:28:34 AM
Hmm... With HDMI to the HDTV, you should have gotten audio through the TV speakers. Check your default audio device and make sure it's set to the optical link (probably something like Realtek HD optical).
-Wolf sends
m
l
October 20, 2011 1:49:59 PM
Well yes I do get audio from the HDTV, but I want it through my surround sound that I have set up around my room. I checked in the tv settings but it only has the "Source" input as HDMI 1 and then the optical technically should send audio out to the RCA 5.1 dolby...
m
l
Best solution
a b D Laptop
October 20, 2011 2:38:40 PM
Sorry. I misunderstood.
So you have HDMI from the laptop to the HDTV and Optical from the HDTV to the surround sound.
First thing that comes to mind is whether the surround sound system is set to the right input (silly, I know, but it happens).
Next I'd make sure that the optical port on the Coby TV is, in fact, and optical output (not an input).
Next, with the optical cable connected to the HDTV, look at the other end of the cable. You should see a red light. If not, there is no output from the TV.
Finally, I'd check your TV settings to see if there is an audio - optical out option that needs to be set.
-Wolf sends
October 31, 2011 3:06:03 PM
Best answer selected by cgort90.
m
l
October 31, 2011 3:11:47 PM
I will have to try that red light check. I did search all the settings/manuals of the surround and the Coby to put the surround on "optical" and HDTV on HMDI input of my laptop.
What I could try would be buying a headphone to RCA cable to route the sound from my laptop directly to the surround sound. But I wanted to avoid that because HDMI and optical send sound information better than plain RCA and the mess of chords all over my desk lol.
m
l
