Yes No
Ads
Tom's Hardware > Forum > Home Audio > High-End Audio > Optical sound card problems
Forum Home Audio : High-End Audio Optical sound card problems
Hello,
I have purchased a speedlink stage 7.1 PCI sound card. I have sound coming from my computer speakers so that is great but i have no sound via optical cable on my surround system (the reason why i brought the sound card). Please can anyone give me any knowledge of if there is something i should be doing or if this sound card is capable of playing through normal PC speakers AND my seperate surround speaker system. Any help would be greatly appreciated as i'm pulling my hair out (what little i have)
Reply to dsbennett
yes, you can purchase a Y cord, to split the signal...line audio level...wired connection..
or double click the speaker icon on the lower right of the desktop...
can you find audio control software for the mother board, sound card?
did you go all thru, to look for optical control settings?
when you load drivers for the card (or have you?), is the antivirus turned off? do you have multiple security programs running?
Reply to soundguruman
Hi,
Did you ever manage to get this working? I've just bought the same card and don't seem to be able to get anything coming out of the optical out.
Thanks.
Reply to benjemison
the only instructions we can get are what is posted in the manufacturer's website.
there is a quick install guide.
it says.. after loading the CD into the drive and installing the drivers and software, click on start/control panel/sounds and audio devices.
'make the desired adjustments under the AUDIO tab'
and that is a little bit confusing because the install guide says the CD installs software.
i would suggest clicking start/programs and look through the list of programs for the new soundcard software that was supposedly installed.
if you find such software, you can take a screenshot of the program by pressing the 'print screen' button on the keyboard.
then go to start/programs/accessories/paint
open the paint program and select 'edit' from the menu list.
then select 'paste' from the edit dropdown menu.
save the picture and upload it to one of the photo hosting websites.
we can then take a look at what options are available to help you turn on/off the optical outputs.
i mean.. the soundcard has optical outputs to use a fiberoptic cable to the receiver.
but it also has S/PDIF which is the copper version of digital signal communication.
the alternative digital connection might be a last resort before you send the soundcard back .. IF you are willing to keep the card while it is refusing to turn on the optical output.
personally.. if i bought a soundcard and it has optical output, it should work or i'd send it back.
------------------------------ nature.. time.. and patience are the three great healers
Reply to anwaypasible
hi,
thanks for your reply. i'd searched for any installed software and there was nothing that came with the latest win7 drivers. the only place i could see any settings was in cpanel, hardware and sound, manage audio devices. still nothing that seemed to enable the optical out.
anyway, after much surfing i can across this post: http://forum.xbmc.org/showthread.php?t=55727
it links to some drivers on google code someone has put together for cmedia based cards: http://code.google.com/p/cmediadrivers/
i installled the drivers from CMIDriver-1.2.6-bin-x86-WaveRT.zip file and after a reboot the magical red light appeared from out of the toslink cable. i plugged into my bravia home cinema and amazingly it just works! any sound from my pc outputs to my home cinema. the bloke who has written these drivers is a genius. why the manufacturer can't manage it is frustrating to say the least as i'm sure i'm not the only person who's been struggling.
thanks for your help anwaypasible.
Reply to benjemison
There are 1624 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
