Blinking power LED
  • Flat Panel Monitors
  • LED Monitor
  • Power
  • Monitors
  • Peripherals
Last response: in Computer Peripherals
March 22, 2010 11:57:30 AM
This issue is quite silly but its still an issue:
I have two LCDs:
Samsung 2233 BW and
Philips 190c1sb
Thing that SHOULD NOT happend is when I turn off PC attached to any of these monitors LED lamp keeps blinking, forever!
Is there a way to turn this annoying LEDs OFF ?
More about : blinking power led
a b C Monitor
March 22, 2010 1:22:25 PM
Do you turn the computer off, or put it on hibernate?
Are the monitor LEDs flashing green or yellow?
Have you tried the monitors on other computers, to see if they still flash?
Anonymous
a b C Monitor
March 22, 2010 4:49:05 PM
A small square of black insulating tape might end the annoyance ?
March 22, 2010 7:59:38 PM
they are flashing:
samsung - blue
phillips - white (which is much better)
there is notihing wrong with my pc or monitors .
they are all new
Problem is in DESIGN
I dont know what designers where thinking . "We will leave this LED flashin just to remember user that his PC is off now" or maybe they think its just COOL to have some LED flahing in the MIDDLE of the night in a bedroom when people are trying to sleep.
You know what I am thinking on opening monitors and look for LED lamp and disconect it somehow.
or
maybe easier to do, I will just use black tape to cover led light and have sleep well
Does anybody have some other oslution ?
March 22, 2010 8:03:42 PM
Yes fihart I think I will just use the tape :hello:
a b C Monitor
March 22, 2010 8:04:49 PM
Tape would be the easiest fix.
