Electrical problem with laptop
  • eMachines
  • Laptops
  • Power
  • Computers
Last response: in Computer Brands
November 23, 2012 10:21:15 AM
My e-machine laptop power on in the few minutes it off again,what is the solution
More about : electrical problem laptop
a b D Laptop
November 24, 2012 9:39:21 AM
There are a number of issues that can cause that behavior. Two of the most common on laptops are heat and bad battery. Do you have a means to check your battery voltage? Does it shut down even when plugged into the wall? Can you feel heat coming from the vent on the side (or back) of the laptop?
m
l
