Yes No
Ads
Tom's Hardware > Forum > Home Audio > General Discussion > [Solved] Want to buy a Home Theater Audio system
Forum Home Audio : General Discussion [Solved] Want to buy a Home Theater Audio system
Best answer from rexter.
Hey there everyone!
I am going ahead with a new HTPC build for my living room. I have all the components at hand but i can't seem to choose between the various makers of home theater system solutions.
Approximate purchase date : in less than a month
Projected cost : 200~250 UK pounds
Speakers setup : 5.1~7.1 (I'd like a 5.1 channel system, but most of the movie content i dwnld are in 2 or 6 channel>i'm open to suggestions on that)
Size : Compact, wall mountable and not over (could have the rear 2 speakers on stands)
I/O : should be able to handle coaxial and/or optical audio from a SupremeFX X-Fi or a Gigabyte H55m-USB3
One other issue i'm boggled with, do i need a amp/receiver for the setup? I'll only have my HTPC to do ALL my media needs.
I'd also appreciate it if you guys can guide my purchases on uk sites. Preferably, amazon.co.uk or any site that is favourable.
Thank you all for your time.
Message edited by Lutfij on 11-11-2010 at 08:10:35 AM
Reply to Lutfij
250£ you are probably best off with integrated multimedia speakers, i.e., Logitech Z-5500.
Reply to astrallite
but i'm going through amazon.co.uk and i can find home theatre systems from Panasonic, Sony and BOSE.
Ok, then how much would i need to go ? :) I suppose i should go out in style with my living room :D
Edit: I've been looking around amazon and stumbled across this and I've been reading its review and connectivity options
what dya think?
Message edited by Lutfij on 11-11-2010 at 09:24:25 AM
Reply to Lutfij
Quote :
Reply to Lutfij
So you don't play video games, sing karaoke, play SACDs, or watch HDTV? In that case all you need are computer speakers, since you only need 1 input, ever.
Reply to astrallite
PUN noted :P actually, the family don't do all of the above.
I live in Bangladesh.We watch movies, watch Tv on a Panasonic 43 inch projector tv and haven't moved out of video coaxial input.
I have a relative in Uk, thats why I suggested to look within their sites. I have a rig dedicated to gaming, and that has a 4 point surround sound solution ( also cos the room is small) and am happy with its setup.
The living room however, is alot larger, but I'm deciding to go with a 5.1 setup, and I hope to keep it enjoyable for my folks. You know how old folks are with having too many remotes in one room :P ?
Watching HDTV is all they'll do. Me and my lil' bro will watch downloaded tv shows and movies via the HTPC.
I'm not stubborn on buying the pioneer setup, I'm wondering whether I need such a high end system when I'll be able to use only 30% of its features. I believe , that anything I'll purchase isn't overly packed with features.
Reply to Lutfij
Unless you build a surround system setup with your own pieces, I won't even begin to call it high end.
Reply to astrallite
OK, I'll go ahead with the onkyo reciever, but the speakers could be something different. I'm not a fan of huge speakers.I'd more like to take satellite speakers kinda like the ones BOSE offer.
Reply to Lutfij
Then you should get used to subtitles :)
Reply to astrallite
:D seriously, some suggestions on smaller form factor speakers
Message edited by Lutfij on 11-12-2010 at 06:29:23 AM
Reply to Lutfij
Best answer
At your price range, it is not easy to find a better product than what you already found. The Z5500 will sound louder due to its bass and it's hard to beat when you use its decoder for movies any system at its price range. On music, the Pioneer HTS may sound better if you do not crank the volume pass 70%.
Another option is this one http://www.amazon.co.uk/Onkyo-HT-S [...] 19&sr=1-20 but that'll go over your budget.
Message edited by rexter on 11-18-2010 at 02:21:14 PM
Reply to rexter
I'll go with the one i dug up :) thanks for a lil steer!
Reply to Lutfij
There are 1641 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
