SAMSUNG DLP PROBLEM VERTICAL LINES HLP4663W
my samsung has a large vertical line (all colors) in the right middle side of the tv set. Tried turning the tv off and on but nothing has changed. What gives?
1 answer Last reply
More about samsung problem vertical lines hlp4663w
  1. Try disconnecting cable TV and use a DVD instead.
    If the lines go away, the cable signal is too strong, and is overloading the TV input.
HDTV TV Samsung Home Theatre
