Hi! I'm going to build a a system in a few days with an XP 1800+ Tbred A (it has AIUGA written on it) and I ought to know if the CPU is locked or unlocked BEFORE I get it going. Since I plan to OC it.
All I can tell you is that some of the L11 and L3 bridges seem to have a small cut inbetween them (is this a s k lasercut?) but noone really seems to be connected (no lines between the "Bridgepoints"). Grateful for any help, Oh yes, corevoltage 1.5 according to AMD.
Thanks for any responce guys.
Turk
Turk
