Archived from groups: microsoft.public.broadbandnet.hardware (
More info?)
You high speed modem only has a 10 mbps ethernet port which is what your
NIC is. You only now noticed it because you finally have something that
is faster then it is.
maroush wrote:
> Thanks for all your help!
> I understand I have some PCI slots. I'll check it out. I
> wonder how I got past this problem before with my high
> speed modem.
> Thanks again
>>-----Original Message-----
>>Well the 3Com Etherlink III ISA is limited to 10 mbps.
> Most ISP's only
>>give you up to 3000 kbps (just under 3 mbps). So for the
> Internet that
>>is fine. If you need it to be faster for file & printer
> sharing you
>>will need to purchase a new NIC.
>>Does it have any PCI slots?
>>I don't know of any ISA NIC that supports 100 mbps that
> is available on
>>the market at this point.
>>The only way around this limit is to replace it. All you
> have to do is
>>remove it from device manager. Then Turn the computer
> off And
>>physically change the card for the new one.
>>Maroush wrote:
>>>Hi:
>>>I'm using the 3 Com Etherlink III ISA Network Interface
>>>Card - under enhanced mode (32 bit and 16 bit).
> Bindings
>>>IPX/SPX and TCP/IP. My system has two ISA ports.
>>>Can I purchase ISA cards that go beyond the limit of 10
>>>Mpbs for this router? I never had a problem before
> with
>>>limits as my high speed modem always used the same ISA
>>>NIC.
>>>Is there a way around using the existing NIC?
>>>Please any information you can provide would be a great
>>>help!
>>>Maroush
>>>>Go into device manager and see what model of Network
>>>adapter you have.
>>>>Please post the make & model.
>>>>I believe the most likely reason is either a setting
> that
>>>is limiting it
>>>>to 10 mbps or the device will only connect at a maximum
>>>of 10 mbps.
>>>>Maroush wrote:
>>>>>My wired PC is WIN 98 connected to the basestation
> with
>>>>>the blue wires. My problem is that I can't go beyound
>>>the
>>>>>10 Mbps on the connection speed. I had no problems
>>>before
>>>>>as I had highspeed prior to installing this kit. Now
>>>I'm
>>>>>limited in speed. What can I do to fix this problem
>>>and
>>>>>get back a much better connection speed then the 10
>>>Mbps
>>>>>which I'm stuck with. (?)
>>>>>The wireless PC is ok as its limited to 11 Mbps which
>>>is
>>>>>expected.
>>>>>HELP
>>>>>Thanks
>>>>>Maroush
