Yes No
Ads
Tom's Hardware > Forum > Home Audio > High-End Audio > [Solved] Best 5.1 Surround Sound Headset
Forum Home Audio : High-End Audio [Solved] Best 5.1 Surround Sound Headset
Best answer from mosox.
I want to know what are the recommendation for the best 5.1 Dolby Surround Sound headset. I want the to use them for PC gaming and some recreational listening...budget under $300.
Reply to klemons
you might also want to check the logitech G35
Reply to MEgamer
There are 1610 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
