Well I decided I need to put the side back on that case
but it needed a serious cleaning out first.. so I blew out what I could and got down n dirty with the alchohol/q-tip..
Even took off the heatsink and cleaned it and it's fan out, put on new heatsink coumpound and got it all back together..
and then...nothing.. dead..
The board is an asus A7M-266, running an athlon XP 1700..
I can power it up, the board power LED comes on, CPU fan spins, video card fan spins, and the Northbridge fan just kinda tries to.. slowly jumping forward a little better each time.. eventually getting a decent spin(I tried cleaning it too, after all this started).
My Asus I-Panel (you know I bought this for diagnostics, WORTHLESS) just lights up the msg led.. doesn't even try to get as far as a msg..
It doesn't beep at all.. never gets there..
The CPU doesn't physically LOOK burnt in any way..but what do I know? only CPU I ever saw killed shattered the core.. that was pretty obvious.
of course all of the cards came out.. and the video card back in..
I've tried more different jumper settings than I care to mention.. voltages, jumper-free, manual clock settings..etc..
I get nothing..
So before I take the 1 1/2 hour drive this afternoon to get new, is there anyway of knowing if it's the MB, CPU, or both that I'll need?
Even just a probability? :help:
I get nothing..
