Front and Back Panel Audio Do Not Work
Last response: in Windows 7
Hi I just had to move my graphics card to another slot for access to another PCIE slot. And my back audio sound jack stopped working. Ive tried with my monitor speaker and headphones and it does not work. Any help would be good.
Specs:
windows 7
i7 3930k
32gb of ripjaws Z
noctua nh-d14
thermal take level 10 gt
x79 sabertooth
My front panel audio does not work either. I got bios set to HD audio and i am using the hd audio plug
any help would be good.
:D
Driver Expert
Graphics card Master
Windows 7 Authority
Go to Control Panel/Sound and verify that the proper playback device is selected as default. Sounds like when you moved the video card, the system may have selected the video card's HDMI audio device as the default. Just change back to the "regular" HD sounds device.
Related ressources
Specs:
windows 7
i7 3930k
32gb of ripjaws Z
noctua nh-d14
x79 sabertooth
:D
Hi I'm wonder if you ever got to bottom of the problem.
I've had exactly the same issue on Sabertooth 990FX R.20. I bought a new graphics card and it was longer and didn't fit in the top slot because of my HDDs so I stuck it in the middle slot. Everything loads up fine except no sound from the back panel anymore (haven't tried the front yet, don't have a panel) . I can get sound from the NVIDIA HDMI. I have the issue in Linux and Windows so I don't think its software related.
