so i have a hpzd7020us with a bad ac power jack and i'm trying to get to the mother board to fix it and or replace it.. wonder if anyone has fixed this on their zd7020us?
my question is in looking at the service manual at 5.2 Disassembly Sequence Chart is that: do i need to remove everything listed previous to the steps for access to the system board to replace the jack or can i just start with 5.12?
wonder if anyone has done this and can save me time before go the long way and maybe i don't need to remove everything preceding the system board and go straight to 5:12 and follow those steps only.
Use the chart below to determine the section number to be
referenced when removing notebook components.
Section Description # of Screws Removed
5.3 Preparing the notebook for disassembly
Battery pack
Hard drive
4 loosened
5.4 Notebook feet 0
5.5 Memory module 2 loosened
5.6 Mini PCI communications card 2 loosened (same
screws loosened for
Memory module)
5.7 Optical drive 2
5.8 Keyboard 8 loosened on fan cover,
2 removed for keyboard
5.9 Keyboard cover 6
5.10 Display assembly 4
5.11 Top cover 13
5.12 System board 6 screws,
4 standoffs
5.13 RTC battery 0
5.14 Heat sink
Fans
4 loosened
6 removed
5.15 Processor 0
5.16 SD Card slot/infrared module 3
5.17 Speakers 3
any help is appreciated.
Mark
Battery pack
Hard drive
4 loosened
5.4 Notebook feet 0
screws loosened for
Memory module)
5.7 Optical drive 2
5.11 Top cover 13
4 standoffs
5.13 RTC battery 0
5.14 Heat sink
Fans
4 loosened
6 removed
5.15 Processor 0
5.17 Speakers 3
Mark
