Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Connecting a monitor to a Sony Vaio Laptop (FX103)
Forum Windows XP : Windows XP General Discussion - Connecting a monitor to a Sony Vaio Laptop (FX103)
Archived from groups: microsoft.public.windowsxp.general (More info?)
I am trying to set my sony laptop up with an Iiyama monitor. I have installed
the correct driver for it and the monitor and driver are recognised in
Control Panel / Display / Settings / Advanced / Monitor (in monitor type).
However, there isn't a dual monitor graphical representation in the settings
area and I can't set the proper refresh rate and resolution for the separate
monitor, hence I get flicker. I don't want both monitors on at the same
time, just a flicker free display on the large monitor.
I've just put a new 60Gb HDD in it and a clean install of XP, but I can't
get it to work with the monitor which is annoying. I used to be able to do
this before I replaced the HDD.
Any help appreciated.
Sponsored Links
You might try MultiRes. It's a freeware tray utility that allows you to
change resolution and refresh rate on any attached monitor. I've used it for
years. http://www.entechtaiwan.net/util/multires.shtm
Louis
"Greeny" <Greeny@discussions.microsoft.com> wrote in message
news:1CB805B7-38FA-40AF-9A9E-584E8853CD54@microsoft.com...
installed
settings
separate
do
Reply to Anonymous
Thanks for that, I'll have a look.
I seem to have found a solution by getting an updated driver for the video
card. I still don't see the double monitor image in setup, but teh driver
utility allows me to switch between monitors and set independent refresh and
screen resolutions.
Thanks for your help.
> Louis
> installed
> settings
> separate
> do
Reply to Greeny
There are 540 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
