dharmil007
28
i Have a Sony home theater system of which speakers i Want to connect iT wid my computer.
The system is around 10 years old which has 345W RMS (120x2W + 35x3W).
Model no is SONY HCD-VX90AV for VCD system & SS-VX90AV for speaker system (5 speakers).
The system doesnt have a MP3 or DvD playback just CD & VCD so i Wanna use those speakers wid my PC
But the problem is that it doesnt have a Standard 3.5mm jack instead each speaker has 2 wires output.
So is there any way through which i can connect those speakers wid my computer ???
i Need to buy a new mobo for my AmD x6.
So suggest me which is compatable with that & i will buy that & tell iF sound Card is required oR not ??
dharmil007
28
waht is RadioShack ??
iF u are referring to a store then lemme tell u that i am from mumbai,india so pls tell me stores in my country.
dharmil007
28
& can u PlS eXplain me waht is RCA & Stereo Minijack adaptor ????
& how much do i Need considering i have 5 speakers
astrallite
1,464
dharmil007
28
Hey thanks now i Know taht waht is RCA & STEREO MiNiJack Adaptor.
But problem is my speaker wires are not RCA type it has just 2 wires which needs to be attached to the speaker & VCD player.
dharmil007
28
The connectors on the speakers are not the RCA type .
Both VCD player & the speaker have the same type of connectors but VCD players also have many Other connectors.
Below the VCD player connector iT iS written "IMPEDANCE 8-16ohms".
iF u want to see the image u can check the speaker model no & check iTs connector
dharmil007
28
