S syqadri Distinguished Apr 5, 2010 1 0 18,510 Apr 6, 2010 #1 Hello,My printer LJ 4Pnow giving problem after pring first page message paper jam solution???
G Guest Guest Apr 6, 2010 #2 Try fanning the paper before loading it. Try a lighter grade of paper. Upvote 0 Downvote
afciscoguy Distinguished Mar 19, 2010 14 0 18,510 Apr 6, 2010 #3 If that doesn't work, HP sells a maintenance kit that will allow you to replace the rubber feed mechanism which should take care of this. Had the same issue with mine after a few thousand prints. Upvote 0 Downvote
