Archived from groups: alt.sys.pc-clone.dell (
More info?)
Ogden Johnson III wrote:
> none@no.com (Al) wrote:
>>is it really advisable to pay more for the pro edition? What are any solid
>>reasons for that? Thanks.
> What are you doing with your computer?
> You are the only one that can answer that question.
> FWIW, here's the MS side by side comparison:
http://www.microsoft.com/windowsxp/pro/howtobuy/choosing2.mspx
> Which gives a side-by-side comparison of the feature differences
> between the Home and Pro editions. Look them over, then if you
> have any specific questions on an item, ask.
Pro is needed for a few reasons
#1. You need to join a Windows domain. I run a domain in my house
(becuase I am a systems admin), so I need pro
#2. You want the remote desktop feature. My wife and I use this daily.
I run some things on my computer and some things on hers, but they are
on different floors of my house, so it is nice to make the remote
connection. I also use this feature to connect remotely from work to my
home computers for testing.
If you don't need eitehr of these features, you can usually just go with
XP Home or Media Center Edition.
