Help - Possible Memory Problem?
Last response: in CPUs
System Specs:
Proc: AMD Barton 2800
Ram : Kingston 512 @ 333, and Corsair 512 @ 333
Vid card: Radeon 9700
Win Ver:XP
sound : SB Audigy
Recently my friend has been experiencing crashes and restarts when playing Rise of Nations and Warcraft III. I read through this forum and saw a suggestion that 1) it might be the power supply causing the restart and 2)it might be the ram (the post suggested switching the ram around). So he switched the ram around and then he got a memory error (if it helps, i can post the exact error when he gets off of work). Now his motherboard runs dual channel, so he was running them in slots 1 and 3, but then he tried running them in slot 1 and 2 and hasnt had a problem yet (he only played 30 mins).
Thanks for any advice
Onslaught
Thanks,
Onslaught
More about : memory problem
name the memory error i got something like that white box poped up after i reseted saying memory error and a bunch of script turned out if was my video card and i updated the driver to c3.4 and it fixed it
ALWAYS AIM LOW SO YOU CAN'T BE DISSAPOINTED
Two words for you my young man!
MEMTEST86
GOLDMEM
ge that ram tested
<font color=blue>Many modern games <b>must</b> be played multiplayer. And those you encounter online are, almost as a rule, <b>complete and utter cockmongers.</b></font color=blue> :frown:
Ask the community
