G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Ok im confused right now and need some clear thinking. My player step
up unit is not firing the coil to step up the player. I have cleaned
the player unit ant it is functioning manually no binding, coil the
same way. Checked cleaned and adjusted the score motor contact,
cleaned checked and adjusted the player reset relay, clean checked and
adjusted the balls relay. Now i went to check the coil, if i touch my
ohm meter to the two solder joints i can get a reading. If i touch it
to one solder joint and one copper wire going into the coil, i get a
reading. If it touch it to the two copper wires going into the coil i
get no reading. So,, am i looking at a bad coil?
marty
marty
