I purchased a new notebook this week, it arrived yesterday. I left it charging for a while then tried running it on battery power, but it doesn't respond to the power button at all as if it has no battery.
If I power up the machine with the AC adaptor plugged in then go to the power settings panel in WinXP it says the battery power level is unknown, but it successfully lists the battery specifications.
I've tried charging it, in case it wasn't fully charged at first. When plugged in to charge the charge light turns off after about an hour, but if I disconnect and reconnect the AC adaptor the light comes back on for a while. The battery gets warm while charging.
Is there anything I might be missing, or is the battery most likely faulty?
Thanks for your help.
