Can't get subwoofer to work from pc
Last response: in Home Audio
I am running a pioneer 925k receiver from my pc to a 5.1 speaker setup. I ran the setup process where it tests the speakers and the subwoofer makes the appropriate noises but when I try to play sound from wmp or winamp, I can't get the sub to work. I am running sound with optical from the motherboard to the reiever. Much appreciated if someone could give me some advice on this one. I'm stumped
More about : subwoofer work
I figured it out. because of the placement of the subwoofer, (behind my couch) my microphone couldn't hear the sub or heard it too loudly during setup, not sure which. I manually changed the detected distance of the of the subwoofer from the center of the room then the subwoofer kicked in. Thanks for your help.
Ask the community
