PC to HDTV audio problem
Last response: in Home Theatre
November 30, 2011 10:59:21 PM
I recently tried to run RCA cables from the 3.5mm speaker jack on my PC with a 3.5mm to RCA converter cable(6") to my HDTV however when I hook it up through the "HDMI port 1" audio inputs I don't receive any sound on the television, what can I do to fix this problem? The television is an Emerson LC401EM2f 40" LCD HDTV
More about : hdtv audio problem
December 1, 2011 10:06:47 AM
Hey guys,
I recently tried to run RCA cables from the 3.5mm speaker Jack on my PC with a 3.5mm to RCA converter cable to my HDTV, I hook it up through the "HDMI port 1" audio inputs I didn't receive any sound on the television, what can I do to fix this problem?
Can anyone give me some input on that place?
Thanks
Dainard Jackson
m
l
December 1, 2011 11:30:49 AM
How is the video connected to the HDTV? Is the TV set to source: HDMI 1?
-Wolf sends
m
l
December 1, 2011 12:34:19 PM
yes i had the TV source on HDMI1. and i have the pc hooked up with a dvi to hdmi cable and rca audio cables running from the speaker jack through a 3.5mm to rca adapter to the HDMI audio jacks on the television and i still receive no sound when on video sourse: HDMI1.
m
l
December 1, 2011 12:43:01 PM
Actually when I tried it I didn't have a video source hooked up, just audio, I didn't think it would make a difference.
m
l
December 1, 2011 12:52:23 PM
Try it with the video connected. I wouldn't be surprised if that is the issue.
-Wolf sends
m
l
December 1, 2011 1:47:20 PM
ok Iill do so and post back tonight, thank you for you're on going help :D
m
l
December 1, 2011 7:17:08 PM
does your video card support sound over dvi? if so why are you using rca cables? before i had a dedicated receiver i had a direct pc to tv dvi-to-hdmi cable and i had perfect sound. if your unit does support this then perhaps the cable you have is not one of the ones which works for this.
as far as the auxilliary audio input ports on the tv go... perhaps there is a setting or mode you need to be on to use them. browse around the settings on the tv and make sure that the pc has the right audio device selected.
m
l
December 2, 2011 2:40:32 AM
well its a vga to hdmi ran through a dvi to vga, will it still support sound this way? i do not have a dvi to hdmi cable currently.
m
l
