Double-Click to OPen Item (Does Not Work)?
Archived from groups: microsoft.public.windowsxp.general (More info?)
I installed a new Microsoft Mouse with supplied software. That for some
reason change my "double click to open item" and when I double click to open
an item it high-lites the name as if I were renaming the item.
I finally uninstalled the software that came with the mouse and reinstalled
my other mouse and software. Now I cannot use the double click option to open
an item. I have reset the double click option to no avail.
What can I do to return WindowsXP Home (all updates are applied) to open an
item when I double click?
Thank you for your help in advance.
4 answers Last reply
More about double click open item does work
  1. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Try uninstalling the mouse in Device Manager (Start...Control
    Panel...System...Hardware Tab...Device Manager button)
    Then reboot your system and let Windows re-detect the mouse.
  2. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Hi,
    You are needing to change it back to Explore via File Types/Folders as
    Default.
    Or run Explore on line 215 (right hand side):
    http://www.kellys-korner-xp.com/xp_tweaks.htm
    All the Best,
    Kelly (MS-MVP)
    Troubleshooting Windows XP
    "TonynMI" <TonynMI@discussions.microsoft.com> wrote in message
    news:597C9F54-BA55-4D5C-A2F5-9056635948ED@microsoft.com...
    > open
    > reinstalled
    > open
    > an
  3. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Thank you both for responding. I tried everything for the past month and last
    night finally figured it out. I had to reduce the double-click speed in
    Mouse Properties. I had it set on FAST and thus it would not recognize the
    double-click. Nothing is simple with Windows. It seems to be a hit-n-miss.
    Thanks again!
    "Kelly" wrote:
    > Hi,
    > Default.
    > All the Best,
    > Kelly (MS-MVP)
    > > open
    > > reinstalled
    > > open
    > > an
  4. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Now that is fast! :o) Glad you have it sorted.
    All the Best,
    Kelly (MS-MVP)
    news:E6330588-53A8-4F49-96F6-DFBC2E2CE8D6@microsoft.com...
    > last
    > Thanks again!
    > "Kelly" wrote:
    >> Hi,
    >> Default.
    >> All the Best,
    >> Kelly (MS-MVP)
    >> > open
    >> > reinstalled
    >> > to
    >> > open
    >> > open
    >> > an
Mice Microsoft Software Windows XP
