G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have a Dell Dimension 4600 which came with 2 5.25" bays, and I want
to move it to a case with 4 bays. Problem is, I see on the motherboard
that the control panel connectors (speaker, power switch, etc) are all
1 plug. Is this some proprietary Dell stuff, or is this a new standard?
Also, the fan is latched inside the back of the case, is that one
standard? Will I be able to get a case to replace this one, or would I
have to buy a new mobo/case/fan? If there are any cases I can get, can
someone point me in the right direction?
Any help would be much appreciated.
-joltman
-joltman
