G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I just picked up a taxi machine at auction , the machine tech at the
place told me last time he plugged the machine in that it worked but
the display didn't come up,,,, well,,,, the only thing that comes up
are the GI lights.
I started poking around with my finger,, checking fuses and such and
the side of my hand touched the heat sink on the Q3 transistor and I
got a pretty good little jolt!!!
I checked voltages at all test points and they were all very low, I'm
going to replace all the elecrto caps for sure due to age but the
getting zapped thing has me a bit puzzled,,,,is that normal??? I have a
bunch of other machines and I've never got nailed from a heat sink!
Also,,, the 3 diagnostic LED's the the cpu do nothing,,,,obviously due
to the low voltage,,,,, I guess the questions is could this whole power
supply go bad? or is there something else that caused it to go out. Oh
yeah,,, the fuse at F3 was blown.
Any help would be appreciated
Thanks,
Shanda
are the GI lights.
Thanks,
Shanda
