Archived from groups: rec.games.pinball (More info?)
Recently the T-Rex on my JP hardly moves at all side to side. During boot
up diagnostics T-Rex will move about an inch and not find center. He can be
on either side of center when this happens. In the diagnostics mode I can
move him side to side and the left, center and right switch are activated.
I have his side to side feature turned off to play now.
Also I noticed recently that I can lose the background sound with just the
voices coming thru. As soon as ball is drained and fed into shooter the
music returns. Don't see a pattern on when this happens.
Anyone?
Brian
"Amyotte" <amyotte@personainternet.com> wrote in message
news:11d2jmagdjahs20@corp.supernews.com...
> be on either side of center when this happens. In the diagnostics mode I
> can move him side to side and the left, center and right switch are
> activated.
> An ideas???
> Thanks
> Brian
Brian,
I had the same problem with my T-Rex's movement. I reflowed the solder
on the relay board and that fixed it. I think the shaker motor will
take its toll on some of these solder connections. Hope it helps, Tom
Amyotte wrote:
> Anyone?
> Brian
> > activated.
> > An ideas???
> > Thanks
> > Brian
<tomvd1@comcast.net> wrote in message
news:1121091389.286582.31640@g44g2000cwa.googlegroups.com...
> Brian,
> Amyotte wrote:
>> Anyone?
>> Brian
>> > boot
>> > can
>> > I
>> > activated.
>> > the
>> > the
>> > An ideas???
>> > Thanks
>> > Brian
Thanks Tom
Just tried your suggestion and no change.
It's as if the CPU is telling the relay to toggle the different directions
before any ground is covered.
