Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
To All:
I have a MS Base Station MN-500 and I have a MS Notebook Adapter MN-520 for
my laptop, both on XP. Everything works fine between the two, but I'm
curious as to why my desktop do not have the "Wireless Network Connection"
feature in "Network Connections". Is there a way I can turn the feature on?
Is it not true that I could connection to other wireless networks with my
base station if I want to? I see other networks with my laptop and the
"Wireless Network Connection" feature.
My second question, I've been trying to setup an Apple Airport Express with
no success. I've entered the device's MAC to my MAC Filtering security for
my base station, plus disabled firewall and WEP, but I still can't make a
connection. I can't be sure about the SSID or channel, but apparently, the
airport express device suppose to be able to adopt whatever it finds on the
network. I will try with my laptop later tonight.
When I use the Apple software that came with the device, one of the first
error message was something to the effect of "windows do not have
permissions to control wireless network connection" - but I'm not running
any other 3rd party software other than what came with my Base Station. Why
am I getting that message? Is it because I don't have the "Wireless Network
Connection" in my Network Connections? Again, I don't why my desktop is set
up differently from my laptop.
The wireless network connection is only listed when you have a wireless
network card installed in the computer.
The desktop can only connect to wireless devices that have connected to
your router.
What kind of networking device is the "Apple Airport Express"? Are you
trying to get it connect via wired or wireless? What is it connected to?
Also on Windows XP computers it is recommended that you uninstall the
broadband networking software because it is only need to configure
wireless connections on versions of Windows that don't support wireless
security. (It adds WEP support to older OS's while SP2 for Windows XP
includes WPA support for wireless.)
Terence Lee wrote:
> To All:
> Any help or insights would be appreciated!
> Thanks,
> T
Thanks for the response. The Airport Express can work either as client or
base station. (http://www.apple.com/airportexpress/) I'm trying to connect
to it wirelessly. I also have an EPSON wireless printserver. I'm able to
connect to that easily. I should be able to connect to this Airport Express
in the similar way, but I can't...
"joker" <no-spam@netzero.com> wrote in message
news6F6giIgEHA.3612@TK2MSFTNGP12.phx.gbl...
> your router.
> Terence Lee wrote:
> > To All:
for
Connection"
on?
my
with
for
a
the
the
first
running
Why
Network
set
> > Thanks,
> > T
Airport Express requires that your router or access point support WDS
(wireless distribution system). The Microsoft base stations do not support
WDS.
> client or base station. (http://www.apple.com/airportexpress/) I'm
> trying to connect to it wirelessly. I also have an EPSON wireless
> printserver. I'm able to connect to that easily. I should be able
> to connect to this Airport Express in the similar way, but I can't...
>> wireless network card installed in the computer.
>> to your router.
>> you trying to get it connect via wired or wireless? What is it
>> connected to?
>> wireless security. (It adds WEP support to older OS's while SP2 for
>> Windows XP includes WPA support for wireless.)
>> Terence Lee wrote:
>>> To All:
>>> 520 for my laptop, both on XP. Everything works fine between the
>>> two, but I'm curious as to why my desktop do not have the "Wireless
>>> Network Connection" feature in "Network Connections". Is there a
>>> way I can turn the feature on? Is it not true that I could
>>> connection to other wireless networks with my base station if I
>>> want to? I see other networks with my laptop and the "Wireless
>>> Express with no success. I've entered the device's MAC to my MAC
>>> Filtering security for my base station, plus disabled firewall and
>>> WEP, but I still can't make a connection. I can't be sure about
>>> the SSID or channel, but apparently, the airport express device
>>> suppose to be able to adopt whatever it finds on the network. I
>>> first error message was something to the effect of "windows do not
>>> have permissions to control wireless network connection" - but I'm
>>> not running any other 3rd party software other than what came with
>>> my Base Station. Why am I getting that message? Is it because I
>>> don't have the "Wireless Network Connection" in my Network
>>> Connections? Again, I don't why my desktop is set up differently
>>> from my laptop.
>>> Thanks,
>>> T
yikes! that's new to me. Thanks for the info. Is there any place /
website that talks more about WDS and MS base stations not supporting it?
thanks, T
"Barb Bowman (MVP-Windows)" <barb@nospam.com> wrote in message
news:%23$lEoMJgEHA.1644@tk2msftngp13.phx.gbl...
> WDS.
> >> to your router.
> >> connected to?
> >> Terence Lee wrote:
> >>> To All:
> >>> from my laptop.
> >>> Thanks,
> >>> T
> Barb Bowman
> Expert Zone Columnist
> http://www.microsoft.com/windowsxp/expertzone > MS-MVP (Windows)
On Thu, 12 Aug 2004 11:26:27 -0700, "Terence Lee"
>thanks, T
>> WDS.
>> >> to your router.
>> >> connected to?
>> >> Terence Lee wrote:
>> >>> To All:
>> >>> from my laptop.
>> >>> Thanks,
>> >>> T
>> Barb Bowman
>> http://www.microsoft.com/windowsxp/expertzone >> MS-MVP (Windows)
