G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hi.
I purchased a TOM this weekend, and during the move, I had to remove
the legs. Part of the process to remove the legs included lifting the
playfield, and removing nuts that were on the inside cabinet. While I
was removing the nuts, I think I pulled out a connector that controls
the lights in my backbox.
Now, I none off the lights on the translight work. There is no
illumination whatsoever on the translight.
I tried to reconnect the connector, but I have no clue how to do it.
It is located at the front of the cabinet, directly below the plunger.
It seems as if it wants to fit, but nothing happens when I put it into
position. This isn't a normal looking connector. There is no
male/female dicotomy. It is simply a white square with some metal
blades on the side which don't appear to line up with anything.
Am I focusing on the right area?
No error message comes up on the menu, and when I try to run the test
for the lights, the translight simply does not light up. I checked the
bulbs, and they all appear to be in good shape (i.e the filament inside
is still connected)
Can someone offer me some insight to help me troubleshoot this problem?
Xerico
Hi.
is still connected)
Xerico
